Originally Posted by JuliusB
I took the rims to a local tire install company and they were measured to be somewhere's around 8.5 to 9" where the hubcaps would fit i.e. either inside or outside the center cap area
The big problem is trying to get an accurate measurement. I tried using a tape measure for the measurements posted below. I'd suggest finding someone with a brake drum gauge (tool) to measure it for you. Something like this:
Brake Resetting Gauge (princessauto.com)
Assuming that my wheels were original, there are 4 knobs projecting outwards from the raised circle outside of the wheel lugs. I measured them at ~9-3/8" from outside edge to outside edge.
I measured the inner lip on the baby moons that were on the wheels and found it to be 9-1/8". Which might explain why they were so hard to get on and off. It also explains the damage to the moons from people putting them on.
I just bought replacement Dexstar / Kenda powder coated wheels from etrailer
https://www.etrailer.com/Trailer-Tir...r/AM20214.html
They have 3 knobs projecting outwards. It is hard to get an accurate measurement on those with just a tape, but I guesstimated them to be ~8.25 inches.
Using the formula to find the diameter of a circle from 3 points of a triangle on the circumference. The triangle is equilateral so the angle is 60 degrees. "A" is the distance between 2 points opposite the angle.
Diameter = a/sineA = 8.25/sin60 = 9.5"
(Which makes me think my measurement was off)
etrailer sells a baby moon that is supposed to fit the Dexstar wheels. They just came back into stock. I am expecting them to come in this week.
https://www.etrailer.com/Wheel-Cover...a/AM90086.html
If you look at the images on that page, one shows the inner lip of the baby moon to be 9-1/4". That is 1/8" wider than my existing baby moons. That should make it easier to get them on to what I think are the original wheels.
Once they are in, I will be able to try to fit them on both the "original" and new wheels and report back.
