Hey thank you for the reply.
It turns out that the raised areas weren't solid epoxy as I feared, but actually raised section of delaminated fiberglass cloth. I used my multi tool to cut out around the perimeter of the large raised areas, to now only have a tapered edge with the thinness of fiberglass cloth around what used to be the raised sections 1/8 to 1/4" high.
I've removed all the wood on the floor from the front gaucho/bunk to the central area of the floor in front of the dinette.(It's a 4500). I have kept the upper fiberglass/Gell coat layer to reapply.
The 2" or so of remaining plywood under the edge of the closet and kitchen seems to have dried out, being exposed to air, and seems somewhat structurally sound. I don't know that I want to attack the much bigger job of removing those sections.
Perhaps they are ok, or I should inject wood hardener or epoxy, while I have access to those areas??
I need to have instruction on how to apply the new flooring. My questions are:
1) Should I do anything to smooth out the exposed bottom fiberglass layer? Add bondo filler? Epoxy resin? Epoxy resin with filler?
2) I measured closer to 1/2 " of removed plywood from the floor, not 3/4". Either way I am thinking to use 1/2" and use expoxy and fiberglass cloth to get to level. I am of the impression that I am to sand the bottom fiberglass layer of the trailer floor, wet in a sheet of fiberglass cloth(matt or cloth?), and lay the wetted plywood on top, then weigh it down or screw from underneath to pull those layers together? Then sand and wet the upper surface of the new plywood floor, and add another sheet of cloth, then add the original upper layer of the fiberglass & gell coat floor, and
weight it down to bond.
Does that sound right?
3) Any other things that I am missing or can help?
Please feel free to make suggestions.
