bearing torque for amerigo - Fiberglass RV
Old 09-14-2014, 07:22 PM   #1
Trailer: 1973 Amerigo FG-16
Virginia
Anyone know the proper torque when repacking the wheel bearings on a 1973 16' Amerigo camper. Also, I have quite a few wires that go nowhere. Anyone have the wiring diagram for this model?
tatrailer is offline   Reply With Quote
Old 09-14-2014, 07:59 PM   #2
Bob Miller's Avatar
Trailer: Class A Motorhome
Most trailer wheel bearings are not pre-loaded or "Torqued". Common practice is to repack the wheel bearings, reinstall the hub and wheel/tire and first bring the nut up snug. Then spin the wheel a number of times to seat everything, back off the nut, snug down one more time and then back off about one flat until the cotter pin fits. That's worked on most tapered wheel bearings for the past 80+ years.
About wiring: Having a schematic will usually just make things worse as; a) Gardner Manufacturing (who built your Amerigo) was not well known for following any of the schematics they provided when building and, b) your trailer has been through umpteen owners in the past 40+ years who changed God only knows what in the wiring. Add to that any wire damage and shorts and opens and it's a lot easier to just pull out the old stuff and start from scratch, it's not that complicated.
Old 09-17-2014, 03:58 PM   #3
Virginia
Thanks for the advice about the bearings and the wiring. And yes, the wiring probably has been "updated" many times. I have ran a couple of new circuits myself for my new added lights and for the oven fan.
Old 09-17-2014, 04:03 PM   #4
Google how to repack and install bearings.
Old 09-17-2014, 04:36 PM   #5
Raz
Raz's Avatar
Trailer: Trillium 2010
I'm not sure what axle you have. This is from the Dexter manual. I hope it's helpful.
Raz
amerigo
Torque value for wheel nuts Donna D. Towing, Hitching, Axles and Running Gear 28 03-28-2014 05:43 PM
Torque...what does it really mean? Bonnie n Claude Towing, Hitching, Axles and Running Gear 22 09-27-2012 01:02 PM
torque specs for aluminum wheels? Paul and Libby Smith Problem Solving | Owners Helping Owners 3 09-16-2009 11:21 PM
"Insane" 280 torque in little Mazda3 speed Frank G. General Chat 16 03-15-2007 05:54 AM
Lug-nut torque Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 12-16-2002 02:30 PM
