Hi guys,
I recently acquired a 75 1300
Trillium camper and as I'm redoing the front window, I have come across a problem I would like to solve and I would need some of that seasoned owners thought!
I have asked this on another
Trillium owner Facebook group page but got different opinions so I would like to clear it up a little..
So here it is: I know the top bunk is screwed to the lower part of the window frame but the thing is mine had an extra piece of plywood caped with plastic on the top edge that was screwed between the piano type hinge and the ensolite covering the frame and I was wondering if that was stock from
Trillium or if it was installed by previous owners?... I have some people saying it's stock and others saying their's are all original and don't have that extra "spacer" and have the hinge screwed directly to the ensolite...
I would love you guys input on this since, to me, it just doesn't make sens that Trillium would have aded a spacer to an already pretty weak design??..
I mean, doesn't adding a spacer just gives the
weight an xtra leverage to pull on the screws and wall?..
But maybe they just did so to make sure the window's handles would clear the cushion when on bed position but?...
Second question: If that extra spacer is stock, is the bed side of the hinge screwed on the exact edge of the cushion's plywood base or should it be screwed around 3\4" of an inch in so when it's set in the bed position, the side of the bed sits on the spacer?... (see drawing...)
Last question: As I thought about the design and needed my 13 years old, 80lbs daughter to sleep up there and hope she can follow for another few years, I tried to find a simple way to ad strength to the whole thing and came up with a few ideas but here is the one that I would prefer..
What if I would screw the window back (using 1" #8 ss screws with nylon washers) but use 4 of the flange's holes to put #8 ss bolts that would go through every thing (window flange, fibreglass, plywood frame, ensolite, plywood spacer (*or not?..) and hinge and lock it with ss nuts and lock washers!... Wouldn't that ad structural integrity strenght?
That's only my 2 cents but anybody tried that?
please give me your feedback on it!
Tkx
