Hi all! So I just purchased a 1979
Bigfoot 17' trailer. Seems to be mostly original with some cosmetic upgrades as far as I can tell.
Anyway my first question is about the signal
lights etc just to get it on the road. Tow vehicle is a 2000 Silverado Z71 with a 5.3L. Tested the 7 pin plug and everything seems to check out. On the trailer however some minor issues as follows:
Both Running
lights work (just talking rear
lights, will diagnose marker lights later)
Right signal works but left doesn't
Right brake
light works..... kinda. When running lights are on
light turns off when brake is pressed, when running lights off
light turns on with brake pressed.
Left brake light doesn't work ( no change when pressing brake)
Anyway just wondering if anyone has any opinion on where to start with this! It seems like there is only one bulb each side with dual filaments, on a side note what bulb should I be using ? As well any input is welcome on things to check or common problems on this trailer. This is all new to me ! Thanks in advance and excited to be part of the community!
