Help finding reading light bulb for 2017 scamp - Fiberglass RV
Old 06-26-2020, 06:00 AM   #1
Minnesota
I have a 1017 scamp with the round LED reading lamps. One of the bulbs has fallen out and is hanging by its wires. Not the fixture just the bulb. Does anyone know what is the replaxcement bulb for this. It is not on the scamp parts page. Thanks John
John DL is offline   Reply With Quote
Old 06-26-2020, 07:02 AM   #2
AC0GV's Avatar
Wisconsin
Reading light
Is it still working? I "caulked" mine back in.
https://www.amazon.com/Green-LongLif...81&sr=8-1&th=1
AC0GV is offline   Reply With Quote
Old 06-26-2020, 07:47 AM   #3
Minnesota
Reading light
Thanks for the reply. Yes it is still working. I did think of super glue but that could glue solid to the base. Calk may be by Better but I wanted to avoid this approach if the bulb was cheap. I did see the one you linked to on Amazon but was unsure if it was the same bulb or not. I have not been able to get the bulb base out yet to look for part numbers or base style.
Old 06-26-2020, 09:21 AM   #4
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 2003 F150
Super Glue?
Hi,
Super Glue not a good choice as it requires the joint
to be very tight... It has little gap filling properties.
For loose joints you do not wish to open again I find
that JB Weld Kwik is a good alternative...
Caulking would work better and you would still be able
to remove the bulb for replacement. Go easy on the amount.
Uncle Larry
Larry C Hanson is offline   Reply With Quote
Old 06-26-2020, 09:47 AM   #5
floyd's Avatar
Look on E-Bay, I installed those lamps to replace the reading lamps on my 2004 Scamp and I bought them on E-Bay.
I had one of mine fall apart and, upon examination, I discovered that it reattached
Old 06-26-2020, 01:06 PM   #6
AC0GV's Avatar
Wisconsin
rolling earthquakes
I think they would be great boat lights,
but in our rolling earthquakes, not so much.
Old 06-26-2020, 04:55 PM   #7
Thanks to AC0GV for posting the pic.. since there was no Scamp built in 1017 I did not understand that this is the new style reading light. But once I saw the photo, I realized that the same thing happened to me . The bulb actual comes apart from its base and dangles by the wires.
IIRC I used some JB Weld. IDK if it will hold long term but its been OK for a few trips.
The bulb that came apart on me was a replacement that I got from a high quality supplier - not from China. So I guess the design is the problem. I rarely use these lights anyway so if it fails again I might replace them with a surface mount fixture that does not shake so much.
I've been on a boat is some rough seas that make the trailer on the highway seem motionless in comparison.
light, scamp
What Bulb Style for 1993 Scamp 13 Outside Light? barryra Electrical | Charging, Systems, Solar and Generators 1 07-18-2019 05:29 AM
Running Light Bulb Scamp fusedlight Problem Solving | Owners Helping Owners 6 09-30-2013 09:35 PM
LED interior light bulb replacement Larry Singer Modifications, Alterations and Updates 10 03-11-2012 05:37 PM
Trillium Tail Light Bulb Paul McEwan Problem Solving | Owners Helping Owners 6 06-23-2009 08:47 PM
How many dogs does it take to change a light bulb? Benita Jokes, Stories & Tall Tales 3 02-20-2007 09:58 AM
