2013 13
Scamp : 14,000 Central Iowa
Standard Purchased new in 2013
This is our Green 13 , modified all logos to green instead of red,green frame
Installed when purchased new:
Front bench converts to bunks, Dinette in back converts to bed
No bathroom/toilet
Sink, city water and pump faucet
Dometic 3way
Refrigerator 12volt/propane/120
Forced air
furnace propane
Propane 2 burner gas stove Dometic
One
propane tank
Tan cushions originally
Vinyl flooring originally
City water connections and fresh water tank 12gal
Gray water outlet/no gray tank
Screen door
Fire extinguisher amp; carbon monoxide detector
Bike receiver on back
Fantastic fan, Prewired for AC but not included, we found small window unit that fits in back slide window
One 110 outlet, regular
light bulbs
Attached power cord and adapter store under back bench
Updates:
New last year:
battery, new
tires, new cushion covers from
Scamp blue but actually charcoal gray.
Green accents/logos inside and out, and painted the visible portions of the frame green.
Primed/painted all cabinet doors, with New door hardware hinges and knobs
Curtains Green/gray with coordinating pillows
Laminate added to table top, additional extension for better fit for cushions for sleeping
Flooring covered now by vinyl gray weathered plank wood flooring, with vinyl cove base
Butcher block countertops, with counter extension on side of stove top
Ruvati brand stainless steel sink with bottom grid
Delta chrome faucet
Brushed aluminum backsplash with bead lock trim
Dometic sink recess kit/cover for flat counter using existing stove
Suburban propane water heater 6 gallon
Flo Jet water pump
Outside shower w/separate hose
New twist lock connection and detachable 30amp power cord 25ft
Dometic porta potty in case of emergencies
Additional front upper cabinet added factory ordered from
Scamp
Added new openings/doors for easier access under front bench, bottom of closet, under left back seat
Closet shelves added/adjustable as needed
Boss Audio Marine stereo w/four speakers and bluetooth connectivity, SDcard, USB, Aux inputs
Updated all
light bulbs to LED to save energy when
boondocking
Chrome reading
lights over table/bed
Updated digital thermostat/moved to front cabinet.
Additional 110 outlets inside and outside, added a 12 volt outlet too
Front poly tongue box hiding propane and
battery, additional storage
New Rock shield we want to keep our old one, it has all of our stickers from places we ve visited!
Added
awning rails side/back for Green strip rope
awning and poles, and smaller one for back window.
New seals around door
View this ad at Fiberglass Classifieds -
2013 scamp 13ft
